JERSEYJOE
SOMEONE HELP ME!!!!!!!!!!!!!!!
I AM PUTTING A DIFFERENT TRANSMISSION IN MY JEEP. THE PROBLEM IS THE INPUT SHAFT TIP IS 1/2 INCH TOO SHORT. THIS MEANS IT WILL JUST TOUCH THE PILOT BUSHING BUT NOT ENTER IT. SINCE THE 401 CRANK HAS A STEPPED REAR OPENING COULD I HAVE SOMEONE MACHINE A BRONZE BUSHING THAT SPOTTED OFF THE LARGER OD, THE OD THAT NORMALLY CENTERS THE AUTOMATIC TORQUE CONVERTER?
REPLACING THE IMPUT SHAFT IS NOT AN OPTION.
Yes you could have a long bushing that sits in the original spot and has along hole. The outside would have a step for both diameters. This should work fine . ..what tranny are you using?
JERSEYJOE
A CLARK 285SV. CAN YOU MAKE THE BUSHING?
THE INPUT SHAFT IS THE SAME DIAMETER AS A T-18. MEASURES OUT ABOUT .665
Let me check tomorrow to see if I have some oilite material. Send me a pm tomorrow because we are shipping like mad hounds and getting ready for easter jeep safari in Moab
JERSEYJOE
I would appreciate any help possible. Do you have a detailed drawing of the rear of a 401 crank? I might be able to find someone here to machine it if you can't. I would rather wait for someone with AMC experience and access to an AMC crank.
The Clark transmission might be a pipe dream but I am determine to make it work It is truly FU*KING massive next to a T-18, and it has a 7.6 to 1 first.
Joe I will look into this in the next couple of hours. When/if I make your bushing you better post up some pics!
JERSEYJOE
LOVE TO IF I CAN FIGURE OUT HOW. LAST TIME YOU DID IT FOR ME. ( THE BLUE AMX )
What is the diameter of the shaft where it fits in the bushing?
JERSEYJOE
Same as a T-18. I measured the tip of the input shaft as .665
JERSEYJOE
ttt
