jeepsr4ever wroteTo my knowledge their were only 2 different power steering hoses for jeeps from 1972 to 1995. One had a flair end and the other had a O-ring end. Your saying that the hoses bolt to the box but not to the pump?
The fittings are correct at both ends. The problem I'm having is the sections of steel line at either end of the hose are bent in a manner that interfere with the frame (at the gear end) and the back bracket (at the pump end) I just got off the phone with the supplier and verified what I ordered was for my CJ
I popped a high pressure hose a couple of years ago in Moab. I picked up a hose at the NAPA there. It did route differently than the previous hose. The old one ran under the radiator along the top of the pump, the new one runs along the top of the frame rail. Took a little figuring to get it in, but it did work.
Did you have to rebend it at either end to make it work? The one I have 90's out of the pressure port at the box up towards the bottom of the radiator and out towards the outside of the frame (over the top) but when it lays on the frame the fitting end isn't long enough to reach the port at the box unless I were to un-bend some of the angle out of it. Just seems like the frame is in the way. At the pump the section of steel tube seems to be way too long and the bends/offsets not quite right.
I think I need to look at a few CJ's with P/S and see if I can figure out what's going on. 111!!!
