mike4089 wroteyay...i found my problem......the small oil gear was in the pump upside down.....gonna put it all back together today and hopefully that should solve my problem...........
Don't think there is a difference, unless your original gear is worn on one end.
You mentioned you could see where the gears rode on the cover plate. Assuming you mean the oil filter adapter, you should use a honing stone to smooth the surface the gears ride on, or better yet, install the stainless mid plate that Bulltear sells (smooth the filter adapter in this case too for a good gasket sealing surface).
Since you are seeing this kind of wear, chances are your gear end clearance is loose. If you can see wear on the end of the gears, either change them out or clean them up and set up proper end clearance. If the timing cover cavity walls are worn, you need a new timing cover.
