amx600rr
hi.
i am about to install my adapter on the motor and have a question about routing the oil lines. Was planning on the following:
1. a line from adapter (pres. out) to remote filter.
2. a line from filter to side of block@ preasure sender.
3. plug off "filter in" on the adapter and plug original passage in block at timing cover for preasurized oil from pump.
Is this correct? If so, is the stock dia. of the preasure sender adapter opening(in the side of block) correct, or do you drill and tap out for a larger fitting? (size?)
Thanks for your help.
