1980_Cj7 wroteSo you're saying the higher portion is out of the hole about .0015?
BTW: If or when you go to measure deck clearance on your assembly, be advised that the piston will rock a little in the bore and change the elevation of the quench section of the piston. This scared me when I first measured it - elevation readings all over the place - until I realized what was going on.
