jeepsr4ever wroteIdeally you want the bump steer shock in the same plane as the drag link..........
Are you saying attached to the drag link? When I brought my CJ home the setup on it was stationary end of the stabilizer was attached to the driver side axle tube and rod end to the middle of the tie rod. I just bought a second set of axles and the front axle was set up with the stabilizer rod attached to the drag link. The directions that came with my new stabilizer has it set up the same as my Cj was. :-|
