Thanks for the info...
here is what I have in mind for the moment (part no. from summit):
Carb: EDL-1405 600 cfm Performer (good price, good performance)
Intake: EDL-2131 Performer Dual Plane
Cam: (not sure about this) EDL-2132 Advertised Duration 278/288, Lift .448/.472
Timing chain: SUM-G6618 Timing Chain and Gear Set, True Roller, Double Roller, Steel Sprockets
Springs: EDL-4431 Valve Springs, Single, 1.364 in. Outside Diameter, 93 lb. Seat Pressure
Pushrods: CRN-11660-16 Pushrods, Energizer, Steel, 5/16 in. Diameter, 7.818 in. Length, Ball Ends, Hardened (is this lenght ok, should I use shorter ones?)
I need to determine pistons and piston rings, info welcomed
Port and polish with angle job to the stock head
