I know this might be received as being biased but this is from the Mobil 1 site:
Myth: Mobil 1 will leak out of the seals of older cars.
Reality: Mobil 1 does not cause leaks. In fact, new Mobil 1 was tested in dozens of industry standard and original equipment manufacturers (OEMs) tests to prove its seal performance. It is fully compatible with the elastomeric materials from which all automotive seals and gaskets are made. If an older engine is in good condition and does not have oil leaks, Mobil 1 provides the same advantages as when used in a new engine. ExxonMobil recommends taking measures to repair the leaks, then using Mobil 1. ExxonMobil also recommends following the automobile manufacturer's manual for the proper oil to use.
More Myths
Now for some real stuff.....
Heres some pictures I took at the last oil change on my wifes 95 Camaro. The car has 220+k miles on it and has had a steady diet of Mobil 1 since it's first oil change. The spark plugs in the picture where pulled with about 40K miles on them from an engine with 220+K. The picture of the oil level on the dipstick shows even tho' this motor has so many miles it still does not leak or burn any oil. This oil has been in the engine for the last 5K on an engine with 220+k miles. Don't know if the credit goes to GM or Mobil but I am impressed.
