JERSEYJOE
I AM INSTALLING A DANA 60HD IN MY JEEP (REAR). IT WILL BE A SPRING UNDER INSTALLATION. I HAVE THE UPPER PLATES BUT I NEED THE LOWER PLATES, THE ONES THAT MOUNT AGAINST THE LEAF SPRING. I THINK THAT THIS SET-UP USES SPRING BOLTS THAT ARE SQUARE U SHAPED SINCE THE BOLTS DO NOT HAVE TO WRAP AROUND THE AXLE.
DOES THIS MAKE ANY SENSE? I THINK THE PLATES ARE JUST RECTANGULAR SHAPED, CENTER DRILLED FOR THE SPRING CENTER BOLT, WITH 4 HOLES FOR THE SPRING BOLTS.
NEED TWO OF THEM
JERSEYJOE
NOT SURE, I THINK THE OD OF THE TUBE IS THE SAME AS A DANA 60 THEY ARE JUST THICKER. SEND PICTURE IF POSSIBLE TO ME AT:
[email]JBELFIORE@MERCURYINSURANCE.COM[/email].
REALLY APPRECIATE THE HELP
JERSEY JOE
