You need to figure out your dynamic compression ratio, which will be considerably lower than the static compression ratio. It is affected by the valve events determined by your cam. The later your intake closes, the more compression can bleed off.
Keith Black Silvolite pistons web page http://kb-silvolite.com/index2.php has some real good techincal articles and calculators that you plug your specs into to calculate your dynamic CR. I have been told by their techincal experts that you have to stay below 8 to 1 DYNAMIC CR if you want to run pump gas, even 93 octane. You can go a bit higher with aluminum heads.
