This is the rear output shaft from an early model 20 transfer case. It shows what happens when you side-step the clutch at about 5000 RPMs with 35" tires and a posi. Traction was better than I thought.
This is what happens when you run lifters designed for 90 Lb springs with 135 Lb dual springs.
