All -
Thought I'd ask in this section in addition to the Product discussion forum....
What is a viable way to mount the alternator when using a CSR water pump? The Bulltear bracket that I'm trying to use isn't
quite making it.
Part of the issue is when I try to position the alternator up high, then the heater hose water port on the pump ends up with less then an inch of space.
The way that it currently sits in the picture below, allows enough space to connect the heater hose as well as allowing the belt to line up and not hit anything.
Thanks!
Steve
