76-cj7 http://www.pirate4x4.com/forum/showthread.php?t=556054 Since a 8.8 uses the same sleeve as a AMC20.......you "should" be able to use the eliminator for an 8.8 rear......right? :-| I ordered one from Jegs the other day and it should be here this afternoon. Ima have to letcha guys know wut happens.
76-cj7 It works!!! :!: Did'nt use any shim with it......measured the new spacer compared to the old sleeve and was damn close to being same height.....put her in and got 18-20 in. lbs out of her!
76-cj7 Does anybody know of a fix to remove the Dana 30's crush sleeve??....pinion bearings have slop maybe 4,000 miles and im thinking that all i paid this guy to do was screw everything up #-o Guess im going to be setting up my out axles now :-|
tufcj The Dana 30 is done with shims, there is no crush sleeve. If there's slop after 4K, either it was put together wrong or a bearing is failing. Unfortunately, to reset the pinion bearing preload, the carrier has to be out. You can do it without affecting the gear setup as long as the bearings are good. The shims are under the yoke end pinion bearing, you would have to remove the seal and outer bearing. Bob tufcj
Wrench Man tufcj wroteThe Dana 30 is done with shims, there is no crush sleeve. The short pinion Dana 30's in the TJ's and Zj's DO indeed have a crush sleeve!
tufcj I haven't worked on a short pinion version. Thanks for the heads up. Why do they mess with a design that works, other than a crush sleeve is faster to assemble at the factory? :-| 76-cj7's sig line says he has a 1980 CJ. That would have no crush sleeve. Bob tufcj
76-cj7 Bob you are correct...plain jane low pinion dana 30......i had thought there was a crush sleeve but i guess not.....well all i know for sure is the "mechanic" i paid to set up front and rear r&p said he knew what he was doing or so i thunk. Apparently my axles are the only ones hes ever had problems with 111!!! hahaha but i do plan on tearing into it within the next few months so if anybody has any tips or head ups feel free to send them my way
Jeep-Power tufcj wrote Why do they mess with a design that works, other than a crush sleeve is faster to assemble at the factory? :-| Bob tufcj Apparently, that is the only reason for it-- speed of inital assembly.
JERSEYJOE THE CRUSH SLEEVE SUCKS THERE IS NOT DOUBT BUT THEY DO THE JOB THEY WERE DESIGNED FOR. I KNOW A GUY THAT WOULD INSTALL THE CRUSH SLEEVE, REMOVE IT AND REPLACE IT WITH A MACHINED SPACER AND SHIMS. NEVER LIKED THE IDEA I STILL USE THE CRUSH SLEEVE WHEN I WORK ON THE AMC 20 .
