Here you go... the bracket/adjuster you see on the bottom are for a smog pump.
It's important that the bracket end on the water pump bolt have about a 1/8" spacer under it or the front bracket will crack.
Just to rub it in, the engine is a 60K original mile running 401 that I pulled from a 77 Wagoneer. All virgin and never rebuilt. I got it for only $75. Someone wanted the iron spreadbore manifold, I sold it for $25. :!:
