82Waggy
Thought I would post this up as it is fairly complete and may help others organize their engine projects. Note that this build incorporates the Edelbrock MPEFI kit wich includes a distributor, fuel pump, and other items not listed seperately below.
I laid the list out in an Excel spreadsheet with costs (not included below) to keep track of everything.
Below the list of parts is my finished Blueprint specs.
CORE
401 Block AMC
Crank AMC
Rods AMC
SHORT BLOCK MACHINE WORK
Block Clean Up & Magna Flux Inspection CHS
Deck Squaring CHS
Bore +.040, Hone With Torque Plate CHS
Crankshaft surfacing, .010/.010 CHS
Rod Sizing CHS
Bush Rods for .9272 Floating wrist pin CHS
Balance Rotating Assembly CHS
SHORT BLOCK COMPONENTS
Hypereutectic Pistons, 28cc D-cup KB354 UEM-KB354040-8
Harmonic Balancer Rebuilt OEM 910 4501I
Flexplate, 401 to 727 Pioneer
Rod Bushings Custom
Rod Bolts ARP
Piston Rings, Molly Top Sealed Pwr SLP-E-302K40
Freeze Plugs Pioneer
Main Bearings Clevite 77
Rear Main Seal Fel Pro
Rod Bearings Clevite 77
Cam Bearings Dura Bond
1/2"Head Bolt & Tranny Locating Dowel Set PAS
Crank Oil Slinger PAS
Torque Converter Bolt Kit ARP
Flexplate to Crank Bolts ARP
HEADS
Dog Leg Heads, 090 Castings AMC
Cleaning & Magnaflux Inspection CHS
Mill Facing CHS
Bowl Sizing CHS
Un-shroud Valves/Open Chambers To 63-65cc's CHS
Machine for Guide Plates CHS
Install Hardened Exhaust Seats CHS
Valve Job, three angle with 30deg seat CHS
Stainless Valve Set, 2.025/1.68, 3/8 Stem
Valve Springs, Locks & Retainers, Lifters Crower 84045
Valve Guides, Bronze CHS
Exhaust Seats CHS
Valve Seals
Rocker Studs, 7/16" ARP
Port Matching ME
Guide Plates PAS
Brass Freeze Plug Kit Pioneer
Head Gaskets,.045 compressed, 4.275 bore Victor
Head Bolts AMC
LONG BLOCK COMPONENTS
Timing cover (nickle) W/Pump, Midplate, Adapter Bulltear
Timing Cover/Water Pump Gaskets ROL
Alum Water Pump Flowmaster 1781
Timing Chain Set Rollmaster CS7110
Stainless Fasteners, Pan, Mani, Pumps, Etc PAS
7qt Deep Sump Oil Pan Bulltear
Deep Sump Pick Up Tube Bulltear
Pan Gasket, SCE
Dip Stick Bulltear
Oil Filter WIX 51258
INDUCTION AND VALVETRAIN
Cam, 253/260 dur@.006, 485/502 lift, 112LSA Engle 5254H
Push Rod Set, Hardened
Roller Rockers Harland Sharp
Performer RPM Pro Flo MPEFI Edelbrock EDL-3531
Thermostat Housing, Billet RobbMCPerformance
Thermostat Housing Gasket
Distributor Drive Gears, Bulltear
PCV Grommet HELP 42060
Intake Manifold Gaskets
Stainless Oil Fill Tube/Billet Cap Bulltear
Valve Covers, Nickle Plated Bulltear
Valve Cover Gaskets
EXHAUST
Headers, Tri-Y, Ceramic Coated Thorley DTE-616YC
ELECTRICAL
Mini Starter
MSD 6A
Ignition Coil (E-Core) Mallory MAA-30440
FINISHED BLUEPRINT SPECIFICATIONS
408cid
Cylinder Bore (+.040) 4.205
Deck Height (-.007") 9.201
Reconditioned Stroke 3.675
Reconditioned Rod Length 5.855
Piston Compression Height, 1.510
Piston TDC To Deck Clearance, Neg# = Piston Above Deck -0.0015
Head Gasket Compressed Thickness 0.045
Quench Distance 0.043
Head Gasket Bore 4.275
Compression Ratio w/65cc chmbr, 28cc Dish, per KB calculator 9.160
All right, if you must know I will have spent just under nine grand for all of the above, including the purchase and shipping of core components from across the country. Current status is that all block related machine work is done and I am now waiting on head work to be finished up. Once heads are done I will need to aquire the last 2200 worth of the parts on the list to finish up - so get ready MC cuz most of those remaining parts will be coming from you!
Dusty
:lo1l: :lo1l: :? :sa: =D>
Blown7
You forgot PIC'S!!!!!!!!!!!!!!!!!!!!
I can't read so well but I like pretty pics of parts.
Jeff
82Waggy
Blown7 wroteYou forgot PIC'S!!!!!!!!!!!!!!!!!!!!
Jeff
Ya, OK.
I just set up a pic server so I'll start posting pics soon. Wish we could post direct so I don't have to try and manage so many sites. Ain't there no way to do that here?
82Waggy
BTW,
I also had my 390 machine work done at the same time. What a financial mistake that was. I always seem to bite off more than I really want to chew at the same time.
For now the 390 is on hold until I get my Jeep runnin.
82Waggy
Here's some pics!
Table of Goodies. That's my 390 block freshly machined and bagged at the left end.
Here' my 401 block on the stand. Note the lack of a Valley Bypass Line LOL! That's my 82Waggy chassis behind the block, freshly stripped and painted - waiting to put on 4" springs and install new gears with a Power Lok diff in the back before I paint the suspension stuff.
MPEFI by Edelbrock, courtesy of Bulltear< Best Price I found from them.
The now growing in fame KB354 piston!
Pretty .9272" pin bushing with .0007" fit. No bushing oiling holes used - they just show the rod where to crack! :shock:
Blown7
:lo1l:
I like the EFI !!!
Good choice to bring the engine into the 21 st century.
Jeff
crownedclown68
very nice indeed. i too am building a pro flo 401. i just got done tearing the old girl down, and have already purchased my mpefi (pace), thats actually how i found your post, someone directed me to your post because i was looking for a build list, wah lah, here i am. Thats truly a impressive list, what type of numbers are u trying to achieve? i am trying to reign in about 400 ponies and even more in torque. im still researching different options/combos. what were u going for, as far as usage? street, offroad, both, leaning further one way than the other? i look forward to hearing how yours turns out and any imfo. you might share. until then good luck.
thankyou,
wayne
76 chief
[email]crownedclown68@msn.com[/email]
fuzz401
buy a ring filer for the top rings you will need a .027 ring gap
82Waggy
Somewhere in the forum is a dyno sheet for a 401 that made over 420 ft bs at 3400 and about 350hp at around 4400, as I recall. This engine used a comp X260 cam, a 670 Holley carb, performer manifold, Edelbrock heads, and about 9:1cr with speed pro pistons.
I'm doing some extensive work on stock AMC 090 head castings, using a cam with a little more lift and tighter hydraulic intensity that should grind out some additional torque, the MPEFI of course, and probably a little better quench than the dyno motor. Should make at least the same if not slightly better numbers. I'm shooting for best torque at a lower rpm and do not expect much over 350 peak hp.
Just received my Rollmaster timing set today and have everything else I need on the way from Bulltear to finish the engine. Tranny and Txfr case are done. Also have my 4" lift kit, new diff gears, and other miscellaneous stuff on the way from BJ's to finish the chassis - and the body man is finally hard at work. Should be running in July, knock on wood. Now I just need to pick a body color and get on with it.
donwag
Very nice plan.
That would be me with the dyno'd 401. It is in a 89 GW and I am very pleased with the performance.
I actually have another 401 at the machine shop now with the KB pistons and AMC steel heads with some work being done. I thiink it will make more power and torque than the last bulld with the stock pistons and Eddy heads.
Where did you get "Pan Gasket, 1pc Rubber SCE?" Did not know you could get a one piece pan gasket for an AMC.
Please educate the un-washed (me) ... what is "CHS"
Oh YEAH... Looking good!
82Waggy
Here's the latest:
Managed to misunderstand the timing marks on the Rollmaster and installed it a few teeth off. It has 4 advanced and 4 retard settings, requiring that you choose an appropriate crank keyway and then match the appropriate unmarked tooth to the timing mark on the cam sprocket. Trying to get a 108 centerline and the Rollmaster indexing sheet sucks. Recognized it was wrong and now have to pull it off again.
82Waggy
donwag wroteVery nice plan.
Not sure I have. I don't beleive the listing I ordered it from - we'll see what actually arrives.
Update 05/19/07: Nope. 1pc pan gasket not available. Got SCE 4pc set.
82Waggy
Mudrat wrotePlease educate the un-washed (me) ... what is "CHS"
I listed some of the vendors by accident - the result of copy and paste from an Excel spreadsheet. CHS = "The Cylinder Head Shop & CHS Racing Engines", the machine shop I use and that I have been moonlighting at.
82Waggy
jeepsr4ever wroteOh YEAH... Looking good!
Need more parts!!! :?
:wink: Should be there very soon!
82Waggy
Cool!! =D>
82Waggy wroteMudrat wrotePlease educate the un-washed (me) ... what is "CHS"
Gotcha - mine just goes by "The Head Shop" and their sign is rather 60's looking psyco colors :wink:
