willysworker wroteI have a orig. 401 short block ready to rebuild.
Here is my question? Machine shop says only pistons available for 9/1 comp. are 30 over. I'd like to go 10 or 20 if possible but need a source for these pistons. I'm planning on using stock 401 heads.
Also, what is the best low rpm cam. I have Edelbrock cam, roller timing, intake manifold and carb. on my current 360 that I was going to reuse. They have about 1200 miles on them. But I've been reading the Edelbrock cam is weaker than stock.
About the only off the shelf piston worth a flip is the KB354. It will yield around 9.7:1 with stock 58cc heads, which is a bit high to run on pump gas. It also requires that you bush the rods to accomodate their .9272 pins. The solution with these pistons is to open the heads up to around 63-65cc's (unshrouding the valves will get you close) and zero deck clearance to get compression ratio around 9:1 with a good .045 quench. The advantage with these pistons is a tight bore fit (.0015" - .002") for reduced slap and leakage and a good quench head style (helps reduce detonation and improve fuel burn).
Speed pro pistons will work but have a lousy head style with a shorter compression height - not good quench.
If you want forged pistons you are pretty much stuck with something custom, but these require more cylinder wall clearance (.006" - .012") and must be warmed up before revving to control slap -not really an efficient way to go for a daily driver and can be quite expensive.
For a cam with strong torque across a wide rpm range, look for an LSA of 112 or so. With stock heads there is no need to push over about .450 - .490 lift. In a 401 with around 9:1cr, durations of 258-276 adv seem to work well (about a 600rpm spread between these durations where peak torque is acheived). If compression will be closer to 8.5:1, keep duration shorter to help build cylinder pressure.
Use a good dual plane intake manifold and a 600-700cfm vac secondary carb.
USE A TORQUE PLATE WHEN HONING THE BLOCK!!!!
PS: Just looked at the pics of your Willy's. Very nice indeed!
