does anyone have a carrier for a D30 and an M20 that they could measure the bearing journal diameters. I need to make a set of slugs for my bearing puller and need the inner and outer diameters of the carrier journal.
It is easier to take a old set of bearings and hone them out with a brake one so they slip over.
I have set up bearings and a race for putting them on. I need the dimensions so I can make a slug for my puller to ride on. I don't like ruining a socket or cross pin trying to pull a stuborn bearing off with my puller. My puller is similar to a two jaw puller but instead of jaws I have a bearing splitter. The slug would fit in the end of the carrier where the axle shaft would go and sit on the shoulder and my puller would press against the center of the slug. Hope you can understand my description.
