PaintedRat
Grr, too late for power tools in my apartment, so I did some measuring. Looks like .040in needs to come off to clear, plus min .035 as recommended before. Taking .075+ off the skirt for either side of the piston. The piston measures just as 343 measurments stated earlier. 2.45in from skirt to face, and ledge about .21in thick at narrowest point.
Clear schedule tomorrow afternoon, so I'll try to escape work around 5. I'll update after I make a piston fit.
AMX69PHATTY
Ya sure that's a 3.44 Stroke 304/360 Crank ?
Casting number 3214724.
Rods are 5.875 center to center ?
PaintedRat
Took a quick look and couldn't find the casting number on the crank. Is it visible still in the engine? When I tore down, I got the distinct impression that everything inside was original. The wear on the cylinders made it impossible to remove the pistons, so original crank/rods seems likely.
I clearance one piston skirt last night by less than 1 mm, and it can now pass the crank counterweight. I don't like how much debre stuck to the piston, even after trying to clean it. I'm going by the machine shop to ask a price to remove, then later reinstall pistons. If I can afford that, I'll clearance them all myself and rebalance.
I have bad luck with piston rings, and I expect to break one during removal/reinstall. Any recommendations for a complete new set for a 343, .040 over, 11:1 compression?
AMX69PHATTY
Casting number is on the side of the small part of one of the counterweights. Second one from the front near the main journal. Have heard good and bad things, Maddog Racing / Fast Engine Parts seems to have good pricing, but some claim to have had shady experiences. My understanding is cast rings will seat in easier and faster than chromemoly. Do you have the info about proper ring orientation ? Are you aware that AMC pistons have an offset pin, a specific Front & Back to the piston, and should be mounted to the rod and installed in the block a certain way ? They Rods and caps should have cylinder numbers stamped into them. Install Rods so stamped numbers face outward. Other side of Rod Cap joint has a notch which serves as an oil squirter hole for cylinder lubrication. "Problem" is the rod bearings being manufactured now do NOT have a semicirular notch at the mating ends opposite the locating tabs. There are differing opinions as to if this notch and squirter are needed or not. Some say no, others notch the rod bearings by hand to allow the oil squirter hole to continue to function.
PaintedRat
Had the pistons facing the right way, these pistons have a mark to front. The ring set I got had directions for ring gap and orientation. Rod caps are all marked for order and orientation, but I will double check which way the stamped number on the rod faces. I know they are either all right, or all wrong. Rod beardings have the notch for oil squireter. I've got cast rings now, and if I break one, I'll get a new set of cast. My federal mogul bearings have the notch in them, and I'll be using them if I don't mar up the couple I need to take back out. Rods were installed snug, but not torqued down yet, so I think I'm ok.
EDIT: Talked to the machine shop. He said only 100 bucks to remove and reinstall the pistons, BUT, there is a danger of breaking a piston in the process (I'm just assuming during removal). I'm having them check with Eggy if a single replacement piston is available should that happen, because with my luck it always happens. If no single piston is available, I'll just clearance the piston while on the rod, and clean as best I can.
PaintedRat
After several delays, I got the pistons clearanced and installed. Found out they are Egge brand. I took down each side about 2mm to just under 61mm from face to flat part of the skirt. Each piston clears the counterweights by > .035in.
I used a 4" grinding wheel, then Dremel sanding wheel, then sandpaper to get a clean surface. I removed the oil rings, then dunked everything in gasoline and it was clean of debree. Oiled everything back up and installed. Now I can finally put in all these other parts that are lying around, like the BT toys I just got in the mail...
PaintedRat
I tossed my old intake, and cut off the fill tube to try and reuse. It doesn’t fit even after freezing. Is the oil fill tube tapered at one end, or does it just take a lot of encouragement to fit? Do I just need a new tube?
AMX69PHATTY
Pretty sure the oil fill tube is not tapered.
I've heated up the intake with a propane torch to get it installed.
May I ask when did you get those pistons from Egge ?
Do you have a part number ?
Everyone is looking for 343/360 pistons that are not dished
and that's what you appear to have there. They're cast ?
If Egge has those they could sell a lot of'em.
If a person want's, they can add a breather cap to a valve cover
for oil fill and put a freeze plug in the inatke oil tube hole.
Make sure though to have the sheet metal baffle for thr PCV on the itake bottom.
PaintedRat
They are cast. I'm afraid the numbers were in ink on the piston face. It's gone now. I ordered them in January through Decker when I ordered my gasket set and machine work. Less than $400 I think. I'll try and remember to ask part# when I go in friday.
Note: If it helps anyone, this appears to be the first rebuild on the engine, deck was surfaced, but not extra material removed. At TDC, piston face measures about .040 below deck surface.
AMX69PHATTY
I called EGGE to get the info on the pistons.
Thanks PaintedRat !
Those EGGE pistons are what a lotta folks have been lookin' for.
They have the "as-stock" 1.600 Compression Height rather than
the shorter 1.58 that all the others seem to have
and they're even flat tops or a 2V with a small dish.
You outta have some pretty healthy Compression in your motor.
They're hard to find on the EGGE site, they're listed under RAMBLER, not AMC.
Check out my post in the ENGINES Section here.
Told'em about the crank counterweight problem you had also.
djaponi3
the more I look the more I find especially this whole 343 360 piston thing thanks guys I am in the presence of mechanical geniouses excuse my spelling
PaintedRat
There may be genius here, but it isn't me. I just researched. I don't think I've come up with an original concept yet.
AMX69PHATTY
As a follow up, after contacting Egge again, they reported that the Compression Height
on the cast 343 pistons they sale as being only 1.570, which is .010 shorter
than most other aftermarket dished top 360 pistons at about 1.580,
and not 1.600 like stock pistons, but the Egge's are still flat tops
with valve reliefs, which is still better for compression than the .18 or so deep dish
in aftermarket stock replacement cast 360 pistons.
Understanding is Nick Alfano /b is or will be having made and offering
flat top and small dished pistons for 360's and 401's with compression heights
closer to stock, but not sure if they're cast or forged. Not sure what his website is.
Maybe someone else here knows, or it will show up in a google search maybe.
So that's maybe another possible option now.
djaponi3
they look thinner in the pin area you have marked in blue
AMX69PHATTY
PaintedRat posted the picture with the interference area marked in blue.
Understanding is that is the area where there was a slight interference with
the crankshaft counter weights and some grinding was required.
In the thread there are some dimension values for the distance from top of piston
to that surface for the 3 different pistons, AMC 343, TRW 360, & Egge 343,
and I think the Egge 343 was a little bit bigger in that area.
Here is the picture that is now missing on page 1 of this thread.
The image host I was using, Netscape, was closed down and went away.
I myself do not have Egge pistons on hand to do anything with.
Understanding is PaintedRat used the Egge #L2336 343 4V pistons pictured.
Dimension info from top of piston to surface below pin.
AMX69PHATTY wrote:
From piston top to that surface is about
2.40 on the 360 by TRW
2.45 on the 343 by AMC
2.45 inch from skirt to face ( 343 by egge ),
and ledge about .21 inch thick at narrowest point.
djaponi3
his piston does look thicker in that area than your pics and all the other pics I see maybe he got some early prototypes? I think I am going to close my eyes and just goose it with the 343 2v pistons these should keep comp tolerable for the street according to your calculations thanks again for your helpful insight
djaponi3
I also could have sworn somebody used these and had to install them in the block backwards something to do with offset of pin in piston? or maybe this is just a brain fart
AMX69PHATTY
There is an offset, pistons have notches to indicate which way to install towards the front.
Haven't heard of anyone needing to install them backwards.
About quench, or piston deck clearance, in the overall scheme of things,
at these CR levels I'm not convinced it is a big priority.
Stock type dished 360 pistons have very little quench area due to the large dish.
Only quench are on those is the thin lip around the outer rim.
True quench pistons have a dish shaped to match the head chamber afaik.
Nominal values:
9.208 deck - 1.72 throw (3.44/2) - 5.875 rod = 1.613 pin to deck
1.613 - 1.570 nominal Egge Comp Ht = .043 deck clearance
Stock AMC 343 had .060 deck clear & 360 had .012 deck clear.
The .043 deck clear can be reduced by deck milling or offset grinding the crank if so desired.
I have ran a 343 9.175 deck ht block with a 3.44 sroke 304/360 crank and and 1.580 comp ht
360 dished top cast pistons with 0.000 deck clear for about 20 years.
What has to be watched very carefully is Piston to Valve clearance depending on cam used.
Some day, would like to do a build using the Egge slugs with more deck clearance
to get same CR with more deck clear but less piston volume.
The 360 ~27cc dished pistons have to come up so far since they have the .18 deep dish
and the Egge slugs are flat top or a small ~14cc dish.
Asked PaintedRat about how his performed a couple months ago, but
he has been busy with other things and has not ran it much yet.
djaponi3
thanks again I have always built my stuff on the conservative side and always had regrets after they were done! as soon as I hear from my machinest on block condition and bore size I am going with the egge 2v pistons will keep all posted on progress and clearance issues and I hope to hear some time on paintedrats progress
