joshcrowley wrote
--can I use all of the clutch components from my 258 on the 360 flywheel? and 3rd--what external parts can I use from the 258 (power steering pump, alternator, etc.)?
yes, the 258 clutch pressureplate will bolt to the 360 flywheel (be sure you use the 360 flywheel and not the 258 flywheel). you can use all of your original clutch components.
I used my original 258 PS pump but i had to modify the bracket a little bit. I ended up haveing to purchase a different alternator on my 401.
