commandokev wroteif it won't disengage, you need to tighten up the cable by adjusting the other way
there arent any cables to adjust.....and if i adjust the piece that goes into the throw out bearing the opposite way then i really dont have pressure on the clutch pedal....when i made it longer i could fell the throw out bearing hitting the pressure plate but not enough the disengage it.....
