Mudrat wroteIt depends, not there to see it, but if you are at TDC and have 'about 6*' dialed in, kick it up a bit ...
BUT, you have done all of the above suggestions ... right? #-o
Cap, Rotor, wires ... got good spark at the (new?) plugs (properly gapped :idea: ) YES
Do you have the TFI upgrade? (Just a question)Not until it runs
Verified the splitter fuel filter is doing it's job ... fuel to the carb, overpressure back down the return line ...I made sure fuel was coming out of the fuel filter main line
Ensured you ARE on the compression stroke I'm pretty sure it is; I can feel the piston (about an 1" down) when I stick a small screwdriver into the spark plug hole.
Set the engine at TDC (0* on the compression stroke indicated on the crank!)
Twist the dizzy to about 10* -12* BTDC (you can use a compass or a degree wheel to get closer than a 'guestimate')Which direction do I turn it? I do this after I set the timing mark on 0*, right?
And fire that mother up!!
This process worked for a brand new rebuilt 258 (bored, balanced, ported, polished, some Clifford "stuff", & Webber38) and my 360 (bored, balanced, cross drilled then ground & polished crank, Summit cam, various Edelbrock goodies on top, stock dizzy and headers)
If that doesn't work, you have another problem, low or no compression in the cylinders (strange it would be all of them, but ... you just got this thing in a non-running condition. :-|) Have you pulled the pan and looked at the bottom end? No
Drained the oil and looked for "chunks" :shock: )I changed the oil, for fear of gas contamination. It was old & black, but nothing metallic
Really bad leaking valves?
Timing chain pop a sprocket? Always a possibilty; even on a 6-banger!!! If this would have happened, would the engine spin over freely while cranking? It doesn't really miss a beat while cranking.
What's the 'advertised' milage on this beast?52,2XX
My dad called the P.O. today while he was at work. He said that he was using it on the farm and it started acting up a little. He thought it was having carb. issues, so he replaced the fuel pump.
If that doesn't work, tear it down to parade rest and build it like you want to!!
This is what your looking at over at Jeep 4X4 Center And, NO the numbers do not match the items - don't blame me, send complaints to the Jeep 4X4 Center :mrgreen:
