It depends, not there to see it, but if you are at TDC and have 'about 6*' dialed in, kick it up a bit ...
BUT, you have done all of the above suggestions ... right? #-o
Cap, Rotor, wires ... got good spark at the (new?) plugs (properly gapped :idea: )
Do you have the TFI upgrade? (Just a question)
Verified the splitter fuel filter is doing it's job ... fuel to the carb, overpressure back down the return line ...
Ensured you ARE on the compression stroke
Set the engine at TDC (0* on the compression stroke indicated on the crank!)
Twist the dizzy to about 10* -12* BTDC (you can use a compass or a degree wheel to get closer than a 'guestimate')
And fire that mother up!!
This process worked for a brand new rebuilt 258 (bored, balanced, ported, polished, some Clifford "stuff", & Webber38) and my 360 (bored, balanced, cross drilled then ground & polished crank, Summit cam, various Edelbrock goodies on top, stock dizzy and headers)
If that doesn't work, you have another problem, low or no compression in the cylinders (strange it would be all of them, but ... you just got this thing in a non-running condition. :-|) Have you pulled the pan and looked at the bottom end? Drained the oil and looked for "chunks" :shock: )
Really bad leaking valves?
Timing chain pop a sprocket? Always a possibilty; even on a 6-banger!!!
What's the 'advertised' milage on this beast?
If that doesn't work, tear it down to parade rest and build it like you want to!!
This is what your looking at over at Jeep 4X4 Center And, NO the numbers do not match the items - don't blame me, send complaints to the Jeep 4X4 Center :mrgreen:
