javsst wroteThe main benefit of the scraper is to cut down on oil "windage" in the crankcase at higher rpms. There's potential for up to 10hp
there.
This engine build is going into a 69 AMX that'll see occasional
passes down the 1/4 mile and I expect rpms to be in the 6000
to 6500 rpm range.
For engines that won't see higher than normal rpms, it's my
understanding it really won't help much, if at all.
Steve
The potential return is typically about 3% of the engine's output. Scrapers can reduce the ET of a big block Mopar by about .10 sec. In a 9.6s late 60s Charger that works out to about 30 hp.
Scrapers are included in many stock engines and have been for about 50 years -- they do help at lower rpms. Many people have difficulty believing they also can help diesel engines.
Here is a picture of a full blown scraper setup in a Mercedes diesel (603). This engine is from twenty years ago so this is not some mysterious new information. The scrapers impart a vector towards the sump well.
The scraper design seen here is also used by Porsche and both Porsche and Mercedes were preceded in its use by -- surprise -- Ford. The FE engine has been around now for about 50 years.
