rollbar wroteOK I follow U, got a pic?
So Pat, if I run stock or fender-well headers the line where it's @ will be ok from the heat.
Jim
Nope - no pics of this, but I think you know where the line comes up where you are, filter, under the RAD, turn back at the steering gear, then into the pump.
In your pic, I think the line comes to far forward on the P-side and will be real close to #1&3 tubes. My headers are IN-frame and my fuel line is on the far outside of the frame.
What fuel pump are you using? Electric or the engine driven??
Electric:
I would cut the line back under the body and run a rubber line up the firewall past the fan motor and cowl drain, then come into the carb from the right side to miss the header as it exits OVER THE TOP of your fuel line :shock:
Stock Mechanical:
Ummm ... need to figure something out - maybe cross the line around the bell housing and run it up with the brake line?? In this location, using fenderwell exit (over the top of frame) headers you'll be heating the fuel as it flows just inches by the headers.
Almost a recipe for vapor lock??? :-|
