commandokev
does anyone have a picture or the diameter of the crank pulley for power steering without a/c from a 258 around '72 or so? i need to find the right pulley for this before i take my jeep commando into the rocks again.
commandokev
also, i'm sure this matters, the power steering pump is on the upper pass. side like the gremlins(i looked at a '74 yesterday but, it had a/c).
CJim7
Im taking a guess, but i would think the crank pulleys would all be the same diameter regarldess of PS/, A/C or whatever.
Reason i say this, is when i still had my 258 (with A/C) i scavenged a crank pulley from one of my spare blocks without AC, and it was the same pulley
Or....are you talking about the PS pulley itself... :-|
commandokev
no, it's the crank pulley that bolts to the harmonic balancer pulley. the one that i have is a double pulley which makes it 3 total pulleys on the crank. one of the pulleys lines up with the p/s pump pulley but, the belt hits the water pump pulley. the right one for the crank to p/s has to be of smaller diameter
