The 360 I have now has the fuel pump blocked off by a plate from the previous owner & I wanted to run a electric pump but I'm old school & just don't want to deal w/the potential problem on the trail/road etc.
Questions to follow @ the end of the post. #-o
Here is the set up, look @ the plate if U can see it, it's painted green :? :
Here is the Holley I'm going to run, it's a 600-700:
Here is the intake of which I don't know what kind, I know it's a Edelbrock but is it the performer or can U give me some details on this set up w/the carb:
W/this carb should I or do I need to run an electric fuel pump?
If I can get a mechanical pump, which one do I buy, one from AZ or do I need something more for the carb?
How much psi is required for this carb 600-700 cfm to function correctly?
Carb numbers-Holley, front bowl-11398, back bowl-1169?, horn where the air come in-4776-5 & under this number-2690, On the round part under the horn or air intake where the gasket would sit-5534-Bo.
I know these numbers probably do not mean anything but I am trying to give the most info I can.
I can't find the box it came in but I do remember it saying 600-700 CFM double pumper carb.
Thanks, & sorry for the long post,
Rollbar
