milnersXcoupe with FORGED rods & pistons - what would the upper RPM range be on a prepp'd 360 cast crankshaft ?
milnersXcoupe BREK wroteIs the rotating assembly balanced or not? EVERYTHING GETS BALANCED TO THE MAX :lo1l: No Engine should go back together UNLESS it gets Balanced - even leakers :sa: :t:
BREK Then I would have to say that it depends on your cam spec, and type (solid lifter, or hydraulic). I have been told by a local engine builder that a hydraulic cam (no matter the specs) shouldent be taken above 6k.
