“ULTRA REV KITS” • ROLLER TAPPET (PATENTED) Isky Invention
Invented by Isky in 1958, the original "ULTRA-REV KIT" has now
been copied by most other cam grinders.
A tribute to Isky's
Engineering Designs.
The "ULTRA REV-KIT" is engineered to increase engine RPM and
prolong roller tappet bearing life by pre-loading the roller tappets to
the cam lobe (eliminating stop-start "Skidding".)
Pre-load springs are held in place by lightweight aluminum retaining
bars which install beneath the cylinder head (a drop-in installation).
Special Note:
Included with every set of 1241-series Roller Lifters is a package of P/N 200-RTW Roller Tappet Washers, designed to protect your
Roller Lifters from Rev-Spring “chaffing”.
They are also available for sale in replacement form as well. P/N 200-RTW...set of sixteen (16)
pieces.
ULTRA REV KIT: A device designed by Ed lskenderian .to preload the roller tappet to the camshaft to allow higher rpm. The kit consists of 2 plates which are located on each side of the valley chamber and a spring for each roller tappet. The springs fit between the roller tappet and the valley plate.
Isky doesn't make 'Spring mounting Plates' for AMC -
but has all the 'other' items necessary:
http://www.iskycams.com/ART/products/69/revkitL.png
Go to the Isky site - 'Online Catalog' - it'll open .pdf - go to:
rev kits pg.23
CRANE CAMS has all the parts for their previous AMC 'Solid Roller Lifter Rev Kit' - available - except the 'Spring Plates' - .
