Blown7 wrote1980_Cj7 wrote59.8cc? Is that stock or did you open up the heads some? I've been using 58cc for our stock 6090 heads in running compression ratio figures to try to determine what we'll end up with. If they truly are 59.8, that will help us a little in keeping the CR workable with pump gas.
While you have the engine apart, CC your heads so you won't have to guess.
Jeff
Jeff, how do you do that? Can I just fill the combustion chambers with water and measure how much they hold? I have some 60cc hypodermic syringes, I could fill the heads from them and get a fairly accurate measurement. And no, I don't have a serious habit, ha, ha, they are from giving my horses injections. Or, is there a better way?
I keep reading about opening up heads, unshrouding valves, etc. Is this something we could try at home with a die grinder and Dremel tool, or are much more sophisticated methods required.
