Well it's been a few weeks, and I have removed all the bearings for checking and after inspection I have rolled in all new bearings. When people say wash that block after machining they mean it. I washed, pressure washed, washed with gun barrel brushes, oil galley brushes, washed until I thought I could drink clear water out of it and still I had some debris stuck somewhere. It ended up in the bearings, but then again thats what they are for (besides a foundation for oil). No damage to the crank so I'm good to go.
Stats
Clevite 77 bearings, copper back, standard size.
.003-.0035 clearance.
All bearings show high load (but thats to be expected with Nitrous, and remember I had oil pressure issues in the beginning.
Id like to have a choice of High Performance bearings but what choices have we got for our AMC's? ACL or Clevite. MC should pursue a new vendor.
Connecting rod bearings, number 8 cylinder. The oiling hole is not standard I installed it because I have drilled conn rods for floating pins.
Number 8 journal.
Notice the rub on the crank from the Carillo rods. No big deal. No temperature discolor just a rub, it'll wear in.
Bottom cap of number 8 conn rod, notice the rub on the cap from the crank cheek.
Number 5 main journal.
More pics comming.
