Well after 3 hours of uploading about 5 minutes of oiling videos here goes. Lube wasn't my problem. I realize now that if all the oiling paths are correct the cam gear can flow copius amounts of oil.
Specicifications;
- Engine was rotated and stopped at 50 degrees BTDC.
- Oil viscosity, Valvoline 20-50 Racing oil.
- Used the original oil filter adapter with the bypass.
- Modified a 1515 NAPA Gold filter.
- Plunger for oil pressure was stuck initally,( I just jammed in a plunger I had laying around. I didn't care for maintaining a constant pressure, just to see the flow and document it with the fuel pressure gage.
- The best I could measure the amount of torque required to turn the shaft at 15 PSI was 32 in/lbs of torque required.
( before the last video, I couldn't document it as I had to do this with both hands. No helper. )
First vid just getting started. The oil still has water in it, thats why it's milky but actually gives a good contrast to see.
http://www.youtube.com/watch?v=BIPw9NjKdfM
Second vid, my drill motor chuck kept on loosing up
http://www.youtube.com/watch?v=5xP38DCBgUo
Third vid, drill motor was starting to heat up and I eventually burned it out
http://www.youtube.com/watch?v=j8a4gk78U60
Forth vid I used my big 20 year old Rockwell drill, its shakey but I had to hold the big drill in one hand and the camera in the other.
http://www.youtube.com/watch?v=42ZFJrA19IQ
Conclusions
If all the oil paths are aligned you need no additional oiling mods.
The torque reqired initally is significant, the higher the pressure the harder to turn as evidenced by the counterclockwise rotation on releasing the drill at higher pressures above 70 PSI.
More observations folks?
