Soooooo MC was correct, the holes are open to recieve oil
And as I surmised late yesterday lube doesn't seem to be my problem. I think alignment could be plausable as when you get into gear theory and pressure angles, pitch depth, etc. alignment and clearances can prematurely make gears fail. However I cannot prove or disprove or accurately measure what those dimensions are on my engine with this cover unless I bandsaw the cover up to allow me to take some measurements. I don't feel that motivated at this point to make all those checks. I'll wait and install the new cover with new gears and see where I'm at then. I believe my problem was excessive oil pressure resulting in the cam gear trying to turn the dizzy/oil pump shaft beyond it's designed operating torque input.
I will make a insert of Aluminum to install in the washer or Silicone the washer side to keep a oil tight seal under the cam gear.
Jeff
