82Waggy wroteLooks like the non-driven side of the gear is showing wear as well. Were these gears a matched set?
Yep from our good friends here at Bulltear.
I would have thought the standard oiling holes would provide sufficient oil to the gears, assuming there was flow of course.
Me too, but I didn't even think to look, or think about the 12 and 6 o clock holes and how they would get oil. Thats one of the things I hope MC manufatures in the new billet timing covers is the ability to see when priming the oil pump by hand the oil coming thru the gear oil holes.
Wear looks to be centered up on the drive teeth OK.
What do you think caused this, excessive oil pump load, insufficient lubrication, misalignment?
Good question, for which I don't have an answer. I wasn't at the dyno when Greg removedthe timing cover to weld it. But he did mention the cam gear was worn,he attributed it to the cam bolt backing out, but I don't think or know for sure not having seen it. I know a couple of times we spiked the oil pressure
over 100 PSI for a few seconds.
Improper dizzy alignment might explain the wear on both sides of the drive gear - the binding causing the excessive wear on the driven side - but you would think it would not be so critical at just .007" out.
Interesting.
PS: Oh, maybe the driven gear on the dizzy not being true due to die grinding the shaft is the problem?
I'll get some pics of the coast side of the gear, but there is no wear there or evidence of even touching.
The rest we can all think about because for right now I just don't know,
