How do you account for those that found no measurable drop in pressure from one end of the galley to the other, an excessive flowing lifter? I would have thought this would result in a system wide pressure drop, but if you think there is extra restriction "flowing over the top" to the left side then maybe this in concert with an excessive flowing lifter would account for it. Did you use a restricter plug in the left side galley? No
This was a measurement of the right galley aft (passenger side) to the left galley aft (which showed the lower reading) verses the oil pressure indicating port. A system wide pressure drop if their was one was compersated by my bootyfab oil pressure adjusting screw which was set to maintain a system pressure of 60 PSIG.
If both turns "over the top" is equal to .5 LB pressure drop and then the final 90 degree into the block to the left galley is equal to .25 LB then I would have to assume a 3/4 PSIG reading lower just getting to the left side galley. Not including the pressure drop thru the length of the block. I always likened oil pressure drop to voltage drop in a wire carring a current the length of wire creates a voltage drop due to resistance and length ( just like hydraulic pressure) at the end of the run, same with oil pressure just a lower reading at the left end galley (which is furthest from the oil pump) due to size of galley verses resistance to flow.
The only way to know for sure if the bypass line is working would be to measure the right side galley at both ends with and without the line.
Absolutely in agreement with you there!! Thats why I suggested I'd may install a flowmeter with a one way check valve when I install the engine in the chassis. When we all install the valley oil pass line in the block we all assume the valley line flows oil back to the mains because everyone told us so. As I was playing around with the engine the thought occured to me that the oil could flow either way with the valley line mod (Convential thought is front to back "at the over the top" but it possibly could go the other way, back mains to front if there is a lower pressure "at the over the top" that I myself don't know for sure.) I didn't feel like pulling the blower manifold to disconnect the valley line. When I do the chassis install I have to pull the manifold to weld a crack so I'll have access then.
Jeff
