If a person looks at the AMC block and follows all the turns and obstructions there are many places for a pressure drop.
First and foremost is the oil pick-up tube location...with the long hole drilled going to the pump in the oil pan rail.
Another one is straight out of the cover to the block, a D shaped hole in the cover going to a round hole in the front of the block. #-o
From there it takes a 90 degree turn to go up to the Y in the valley with the 2 screw in plugs. #-o
At the Y lies 3 90 degree turns. (1 over the Y to the other lifters and 2 more turns to go down the block to oil the mains and cam bearings + the lifters the other to oil the lifters side only).
Then there are the 90 degree turns it takes to oil the main bearings. :shock:
While at Tech. College we learned about the pressure drop of a 90 degree turn flowing fluids. Ask any plumpers...
the AMC V8 has at LEAST 7 of these turns... 111!!!
The only way to minimise the turns is to take a small die grinder with a long bit (6" or more) and radius these turns. You can get at all of them except the main bearings with a small bit.
The front of the block in the valley with the 2 plugs should have all the sharp edge raduis with a die grinder.
Grind the front of the block the same as your cover...
I spent many hours just looking for these restictions and grinding them away as much as possible before the block went the the hot tank. I then ran long cleaning brushes through them and cleaned it myself again with parts wash and high pressure air.
I have always had lower oil pressure at idle than most built Chevys...Every dyno guy has ran thousands of these and MAYBE one AMC. They are used to seeing high idle oil pressure...but the oil pump uses HP.
Any more pressure than needed is just robbing HP from the motor and wearing the cam gears and can in some cases can cause timing spark scatter on the dissy.
I even port matched the Indy cover I used to the block...MC I hope your new cover has a matching hole :? (cool stuff at the shop also!!!)
As to the oil mess, I made a big one also when the oil filter gasket went south (or was it west??) on my motor...oiled the ceiling and walls of my grarage. :t:
Going against most chevy guys I wanted more oil on the cam also. So I drilled a few more hole above the cam lobes to drop oil onto the cam. Most races block these holes off to keep the oil from falling on the crank and rods...thus robbing HP. My view was I run my motor on the street and it sees alot of idle time at stop lights. I wanted the cam to have plenty of oil while idling...a good cam will always make more power than one with a flat lobe! :lo1l:
