The finish hone for my 40 over 343 pistons was enough to clean up the bores without going to 60 over. The machine shop said they expect to have parts ready for me to pickup on Friday. This weekend, I plan to start assembly, and paint the block. LQ phone cam pics forthcoming.
Any suggestions on the heads? (Comp Cams recommended a XE256H cam too)
I asked the shop about work to rebuild the heads. I'm having hardened valve seats installed, and they recommended harder valves as well. Standard valve sizes. I also need a bolt hole fixed. I'm looking close to $800 to finish them off figuring HD springs, and tax of $50.
$150 Magnaflux, valve job and surfacing
$160 Labor for seats
$135 Material for seats
$156 Valves (book listed for LPG applications)
My alternative so far is ordering a set of AeroHead Racing reconditioned heads for $679 with hard seats, and larger valves. Add shipping, and a set of hardened push rods, I'm right around the same price.
"These heads have outstanding features that include premium one-piece, stainless stell, high flow valves, heat treated and machined steal retainers and valve locks, seals, bronze wall valve guides, 3 angle valve job, and heavy duty valve springs."
"Select 344/502 Cast Iron Castings, 2.08X1.74 Stainless Valves, 58cc Chambers, .550” Lift Springs, and 3/8 Studs & 5/16 guide plates come standard. "
