:t: :t: :t: :t:
:t: :t: :t: :t:
:t: :t: :t: :t:
Pat I just called..!! Congrats on adding 110 more cubes and 2 more cylinders!! I will be welding today on some parts that need to get out monday morning so dont call me as I wont be answering any shop phones. Sunday work is getting tiresome :sa:
SOUNDED AWESOME..!!!
The first call was like a comedy routine though :?:
fuzz401
I heard it too :t: :t:
Need to record it for psoterity :wink:
BUT, I'm having the same problem as others ... zero oil pressure :shock: I spun the oil pump for about 5 minutes (with my nifty Bulltear rig :wink: ) just to be sure the lines would deliver oil since it's been sitting so long. There's oil forward, but no reading.
Then I wound up having to fix a fuel issue on the daughters YJ so I haven't pulled the valve covers. I need to drop in a mechanical guage. But I don't like plumbing pressurized oil under the dash :roll:
Bad gauge :(: Picked up a set of mechanicals today and plumbed the oil pressure gauge and get 65 Lbs at hi idle :t:
Takes a lot off my mind after all the time and work I've put into this thing. Now for a drive shaft to get it out of the shop to burn off the header paint and break in the cam :?
fuzz401
and tires :t:
