Edelbrock says don't use the stock, use there set (part # 7818).
I can see why they say that too…..to sell more of their chain sets! :roll:
So how much can stock be off from straight up, I think not much. And what about the chain kits where you can advance/retard up to 4 deg IIRC.
So with that said even if stock is off 4 deg all this would do is raise or lower where the power band would be from straight up right guys?
So what do you have the timing set to at idle? What is idle rpm? What is total timing and at what rpm does it all come in by?
Dave ----
