Holeshot
AMC HD Group 19 and race part numbers:
* 448 5727 (L) Factory headers from Jardine, Doug Thorley and Bellanger.
* 448 5726 (R) Factory headers from Jardine, Doug Thorley and Bellanger.
* 448 5741 8.5-quart deep sump oil pan from Aviad Metal or Racing Components.
* 448 5732 Heavy duty brake caliper.
* 448 5733 Heavy duty brake caliper.
* 448 5736 Heavy duty rear brake drum.
* 448 5737 Heavy duty rear brake drum.
* 448 5734 Rear disc brake hub.
* 448 5735 Rear disc brake caliper.
(These parts could be ordered from Ronnie Kaplan Engineering)
* 320 8551 - 4.44 1967 - rear gear set.
* 448 5749 - 3.73 1968 - rear gear set.
* 448 5750 - 3.91 1968 - rear gear set.
* 320 8546 - 4.10 1968 - rear gear set.
* 326 9854 - 4.44 1968 - rear gear set.
* 448 6587 - 5.00 1968 - rear gear set.
* 448 6997 - posi unit.
* 448 5725 290/343 forged connecting rods
* 448 5728 290/343 forged steel crankshaft
* 448 6719 '67-'69 cam,p'rods,lifters,dbl sprgs,seals,k'prs,retainers,studs.
* 448 8413 '70-'71 cam,p'rods,lifters,dbl sprgs,seals,k'prs,retainers,studs.
* 448 5730 AMC opt Holley 950 3-bbl carb with vac sec.
* 448 5731 - 67/69 R4B and carb as a set.
* 448 8410 - 70/up R4B and carb as a set.
