Rules Part 2:
PRIZE MONEY
Contestants must run the contingency sponsor product on their engine during the dyno pulls in order to qualify for contingency payouts and it is recommended that you contact each contingency sponsor to determine their payout requirements. Contestants may only claim one contingency product per category. The winning contingency sponsors will pay the following contingency awards directly to the engine builders.
First Place- $1,500 per qualified contingency category
Second Place- $1,000 per qualified contingency category
Third Place- $700 per qualified contingency category
Fourth Place- $500.00 per qualified contingency category
Fifth Place- $200.00 per qualified contingency category
Sixth Place-$100.00 per qualified contingency category
CONTINGENCY CATEGORIES
Listed are the areas of contingency product categories that are available in the Engine Masters Challenge competition.
- AIR FILTER
- AIR FILTER HOUSING
- BALANCER
- BEARINGS
- CAMSHAFT
- CARBURETOR
- CARBURETOR SPACER
- COATINGS - THERMAL
- COATINGS - FRICTION
- CONNECTING RODS
- CRANKSHAFT
- CYLINDER HEADS
- ENGINE BLOCK
- FASTENERS
- FLYWHEEL
- GASKETS
- HEADERS
- HOSES & FITTINGS
- IGNITION SYSTEM
- INTAKE MANIFOLD
- MUFFLERS
- OIL
- OIL ADDITIVES
- OIL FILTER
- OIL PAN
- OIL PUMP
- PISTONS
- PAINT
- PUSHRODS
- RINGS
- ROCKER ARMS
- SEALANTS
- SPARK PLUGS
- SPARK PLUG WIRES
- STUD GIRDLE
- TIMING BELT/CHAIN
- VALVES
- VALVE COVERS
- VALVES SPRINGS
- WATER PUMP
- CAM BELT DRIVE
RULE SUPPLEMENTS, MODIFICATIONS and/or DELETIONS
PARTS AND TOOLS TRANSPORTATION (9/20/06) SUPPLEMENT Parts and or Tools for competitive entries may be shipped as outlined in TRANSPORTATION section OR these items may be hard carried to the competition. It is the sole responsibility of the competitor that these parts are on hand at the time their competitive entry (engine) is being loaded to a dyno cart for these items to be on-hand. Any parts or tools arriving late may be disqualified.
All engines must be delivered to the dyno site at least FOUR (4) business days prior to the first day of competition; any engine that arrives "late" may be disqualified from the competition.
LOCATION USE SUPLEMENT (9/15/06) WORLD PRODUCTS dynos/ facilities are banned and not available for use by any TEAM or its entry of the 2006 JEGs ENGINE MASTERS CHALLENGE for a period of 2 week prior to the competition. Dates in effect are September 18, 2006 through October 8, 2006.
(8-15 - 1) Transportation/Rule: All competing engines, parts and tools must be crated and delivered to the following address no later than September 28, 2006. The maximum allowable engine crate size is 36" x 39" x 45" tall, including the pallet. Each competitor will be allowed to ship and/or deliver a maximum of 2 engine crates
World Products
51 Trade Zone Court
Ronkonkoma, NY 11779
Attention: Keith Ferrell, Engine Masters Challenge
(8-15 - 4) Camshaft/Rule Deletion: Mushroom style and Schubeck brand or styles of lifters are not allowed.
(8-02 - 1) Headers/Rule Deletion: Commercially-available headers designed and sold with a removable pipe section for chassis clearance are acceptable but, builders choosing to run this style of header must contact the Rules Committee for a written "header exception" ruling.
(7-29 - 3) Cylinder Heads/Rule Modification: "Domestic OEM passenger car" and "aftermarket OEM replacement" cylinder heads must retain compatibility with unmodified OEM passenger car intake and exhaust bolt patterns. Aftermarket cylinder heads that maintain compatibility with OEM passenger car intake and exhaust bolt patterns are acceptable even if the aftermarket manufacturer has altered the valve angles, valve spacing, and/or valve location from the original OEM design. The Chrysler W-2 bolt patterns are allowed.
(7/29 - 4) Oil Pan/Rule Supplement: Electrically powered oil pumps are not allowed.
(4/15 - 2) Cylinder Head/Rule Modification: "Domestic OEM passenger car" and "aftermarket OEM replacement" cylinder heads must retain compatibility with unmodified OEM passenger car intake and exhaust manifolds and rocker location. Aftermarket cylinder heads that maintain compatibility with OEM passenger car intake and exhaust manifolds while maintaining the OEM-type rocker design and location are acceptable even if the aftermarket manufacturer has altered the valve angles, valve spacing, and/or valve location from the original OEM design. Valves must retain as-manufactured valve angles (+ or -1 degree), as originally cast. Cylinder head decks may be milled as long as the milling does not affect the valve angle more than the 1-degree variance allowed by the rules.
(4/15 - 3) Ignition/Rule Modification: Any commercially available ignition system including points, electronic, or capacitive discharge that utilize a single battery-powered distributor and coil are acceptable.
(4/15 - 5) Air Filter/Rule Supplement: Filtered lids are acceptable and are considered part of the air filter housing.
(4/15 - 6) Rocker Arms/Rule Deletion: Maximum rocker arm ratio is 1.8:1, unless the factory OEM passenger car engines of the same family were produced with higher than 1.8:1 ratios.
(5/31 - 7)Rocker System/Rule Supplement: Shaft-mounted rocker systems are allowed. Rocker systems must be commercially available as defined by paragraph (2) of the rules. This includes commercially available shaft rocker systems for engine types not originally equipped with shaft-mounted rockers.
