The PIG Smith wroteOLD SCHOOL CJ wrotei have a 304 with 360 heads due to a big cam i need to go back to 304 heads, my question is what casting # do i need. is there some type of casting# list that i can match with my 304? thanks
I would like to suggest that instead of finding 304 heads for your 304 block, locate a 360 block out of a Wagoneer and keep the 360 heads! :t:
I agree.. Especially If you have minimal money into the 304... But, you said you have a big cam... (What Cam?.. Specs etc)
Anyway, you had these 360 heads on the 304 right?... I'm guessing that you had the block notched for the larger valves?.. If so, won't that play a significant role in power loss if you switch back to the 304 heads?.... I might be wrong so, people please chime in on this...
