The way I understand it, "open-chambering" the head should consist of (at least):
*unshrouding the valves
*draw a circle around your combustion chamber using your head gasket as a template. Then follow the existing angle of the chamber and extend it out to the circle you have drawn, not sure what the step up to the flat of the head is on the edge.
The fresh 401 I recently bought (assembled) has open-chambered heads & the builder said that they are 72cc, as I recall, which he said lower the rated 13.51 pistons (w/51cc heads) to around 111 (I guess I'm too lazy to do the math myself, so I expect to hear from someone with corrections!!!).
This '72 401 is now in a '71 AMX (soon to have Richmond 5-speed) which will be used for Saturday night & Sunday sniping, not a daily driver. I have an R4B w/1050 3bbl, a CrossRam w/2-660s, an UltraRam w/2-660s, or a Torker with a Carburetor Shop 850++ Holley. Between the fully ported heads, dumping plenty of fuel in it (a lil extra to cool the chamber helps), & using a fairly large cam, & the .045" quench, I think I will be able to keep it from pinging. The block is already O-ringed & studded, so I could use a thicker copper gasket if needed. I am not opposed to mixing some 104 into the tank, it actually helps the mileage as well as running better. The outcome of that will determine whether I lower the CR a bit, which I really would rather mill the valve reliefs deeper than open up the quench. Then I would be free to go with more cam later, if desired.
My '69 may ultimately get the CrossRam for nostalgia sakes...
...but an UltraRam with a Bug Catcher scoop looks pretty cool...
