barneybrendan
hi all just jioned the site.i have a ford cortina mk2 which im fitting with a 360 motor.had the engine in a bedford cf250 van for years but needed a change.im in the uk by the way.im building the cortina for drag racing and didnt want to go down the chevy route like most people do in the uk.problem is i dont realy know much about amc engines .any advice on getting the most out of the 360 would be great.realy love a 401 but like rocking horse dung over here.only know of 1 guy with 2 401 motors and he wont part with them.my engine is almost standard just offenhauser 360 inlet holley 650 cfm and a set of headman headers. thanx for reading my essay look forward to any replies...
cj5 buggy
Welcome Barney... this is a great site with lots of knowledge... unfirtunatley i just hang around here to cause trouble... because i'm one if the guys that blew the 360 up and replaced it with a chevy 383 stroker... :mrgreen:
FuzzFace2
This is my setup for my car. only have 7 passes on motor and have not done any tuning other than went to a Holley 750 dp carb after 3 passes with a Holley 650dp. Not much change in times or speed between the 2 carbs.
1970 Javelin 3110 lb
360 - ? compression
291c's stock ports
HS roller rockers
Holley 750 cfm dp race
Edelbrock Torker w/1” 4 hole spacer
Comp Cam 280H cam
Hooker super comp 1 7/8 headers w/ 3.5" torque tubes w/inserts
TH400 Trans 9” convert 3000-4000 stall
4.56 -AMC rear with locker
Caltrac bars stock springs 28x10x15 M/T slicks
Best time - 12.88
Best speed - 103.64 mph on motor only.
Dave ----
AMX69PHATTY
Yes there is a lot of good information here.
Recommend getting a copy of "Performance American Style" book.
Pay close attention to a few Oiling system issues.
Get the Distributor advance curve right.
Holley Double pumper sizing is determined by Minimum RPM at Wide Open Throttle.
Cam to work with Compression ratio and rpm range.
Pistons which give 0.000 deck clearance.
Mild porting of the stock Dogleg exhaust port heads.
Good Valve sprngs and full roller rockers.
My car is a '69 AMX street car, 343 block made into a 360
by using the 304/360 crank, cast pistons about 10.0:1,
Torker Intake, Holley 850 Double Pumper, MSD, Headers,
2.5 full exhaust, TF727 Auto, 3000 stall, 3.73 AMC Posi,
26x8.5 Slicks, pump premium with a little race gas,
Pulls the driver side front tire off the ground a lttle bit at launch,
12.60 sec @ 109 mph, about 325 HP at tire, maybe 400 or so at motor.
My opinion is to first determine what MPH you're after in the 1/4 mile,
and then select components and build to achive that end.
Welcome, a lot of good info here, but slanted to Jeeps and Off Road
and those guys are after low end torque and rock solid reliabilty
which are both good things.
runnamuck
uh, i maybe off but are you sure its a amc 360 and not a ford fe block 360? just checking cause they're whole different beasts.
anyway, welcome.
barneybrendan
thanx for the replies its definately an amc i actualy removed it years ago from a 1972 ambassador.what sort of horse power can you get out of the 360.to start with i only want to spend about £2000 on the engine.realy liking the idea of that 401 alloy block as a longer term build.back to my 360 can i get 500hp out of it without too much work.glad i found this site whenever i tell people what engine is going into my racer they tend to ask whats that.also what companies are best to get parts from.cant get them anywhere in the uk.
youdidwhat
Welcome Barney,
Glad to see you on the sight, I'm another on of the guys that hangs out on the sight dreaming I could do a 401 conversion on my 99 TJ. though I like the 4.0 I would be the only guy in the my Jeep club with a 401 :t:
Hope to see/hear of the progress on you ride.. Got any pic's ?
Be sure to check out the E-store here on the sight as you will be able to find alot of parts desigined for you engine. :!:
am I wrong in thinking 2000 pounds, is about 3500 american$$$. (sorry we do not have the button for the pound icon)
a440plus6
Welcome bud and good luck on your project.....sounds like it will be a fun ride :?:
AMX69PHATTY
I'd say 500 HP would be pretty tough.
HP is a product of Torque and RPM.
High RPM's with an AMC get's tough due to the Oiling system.
It can be done in my opinion, but the budget increases significantly.
Although in my dreams I am wishing for the same thing out of my 343/360
which is out of the car on the engine stand
and has been that way for entirely too long of a time.
barneybrendan
ta ive red about the oiling side of things on old posts.in your opinion what would you budget for for getting 500hp out of this 360.i realy want to keep with amc to get away from the norm(chevy or ford).i dont know of anybody using an amc engine on the strip over here.plus ive had this engine for years and its never let me down doesnt even use any oil.
if its too costly or near impossible to get that from the 360 then i will have to pester the guy i know with the 401 until he gets that fed up with me he gives in.
if anybody has got 500hp from a 360 please let me know and give me a run down of what you had to do..
theres some great reading on here which is getting very addictive.
one more thing has anybody ever twin turbo;d or supercharged an amc engine .
cheers guys.
barneybrendan
as much as i like the amc engine doesnt seem as if its really going to be up for the power i want.been reading all old posts engine seems brill for those jeeps but not ideal for drag racing .so im going to have to go down a different avenue ie ford 460 or mopar 440.all is not lost though just bough a cj with a rover v8 in it.only £200 bin the rover and in with the amc .
youdidwhat
barneybrendan wroteas much as i like the amc engine doesnt seem as if its really going to be up for the power i want.been reading all old posts engine seems brill for those jeeps but not ideal for drag racing .so im going to have to go down a different avenue ie ford 460 or mopar 440.all is not lost though just bough a cj with a rover v8 in it.only £200 bin the rover and in with the amc .
there ya go when givin lemons, make the lemonaid
well thier are a few fast AMC's out there.. but if you are going to make "race car power" (upper rpm range etc.. ) skip the 460 ford..good motor bucket loads of torque..but not real receptive to rpm's 440 mopar? outstanding choice..454 chevy thats ok too..but my personal favorite is the 400 small block chevy..stroke it or poke it or both or niether..makes good power has big block cubes with small block dimensions and they made a boatload of em' as long as you dont mix and match flywheels or harmonic balancers.. (externally balanced vs all other internally balanced chevy sb's)
:mrgreen:
