Holeshot wroteNot enough oil going to the rocker & WAY too much oil pressure - you should be having 1015 psi per 1,000 RPM (1015 psi @ idle, 65 lbs @ 5000 RPM), anything over that is wasting horsepower, heating the oil up, and putting undue pressure on the distributor gears and timing gears.
Again, 65 psi @ idle is WAY TOO MUCH!!!
Depending on the viscosity this is not too much cold. 70psi is where the stock spring (in good condition) is rated at. Remember Dave that these pressure are optimum with a cold engine and can/will drop up to 15psi on a rebuild
