the smaller bore is perfect for Turbo charging or Supercharging,
forget trying to make HP / Torque with crazy comp. ratios / strokes / RPM.
join this group & lurk:
http://autos.groups.yahoo.com/group/jyturbo/
run a single Turbo - you can go 'Blow-Thru' with a carb
http://groups.yahoo.com/group/BLOWTHRU/
or
get 'jiggy' & get an ECM from a Pontiac Sunbird Turbo # 1227749
about $40.00 > www.car-parts.com
the jyturbo group has a few AMC 304 Turbo installs in their Archives.
Turbos:
www.mjmturbos.com
you can run 6lbs.Boost on cast pistons > I'd install some forged so you can twist the Boost Controller.
400HP is easy with a Turbo > and > you can back off the Boost & tool around town on 8.5 compression all day > mild mannered grocery getter until you spin the Controller...........
:t: :sa: :razz: :!: :-|
