I dont know about that Fifesjeep. If you look at the graph here youwill see that a stock 304 makes 270hp with a .448.472 lift and a 204/214 duration with stock compression, stock bore and at 3000rpms. He is at .030 over making 309CI granted he only bumped up .01 in compression he is running a camshaft at .480/.480 lift and a duration of .224/.224 which would put his peak power in that range. If he had some port matching done or valve unshrouding he may be over 350 horse with a bump and a half in compression. I would say 310-320 is around what your running at.
