mika01
Its a 360, 89 block, with 291C ported & gasket matched heads, new valves, new valve seats, new valve springs (Crane), roller rockers, R4B intake, cast manifolds. Its mated to a T18 4 speed with 4.10 gears & 35" boggers.
I've been thinking of going with a Crane Cam 863941 grind number H272-2. It has 216/228 duration at 050 lift. 272/285 duration, .484/.512 lift. Not erally looking at reving past 5000 rpm's.
What do you guys think.
fifesjeep
Seeing that you already purchased the valve springs etc... you might as well match the cam to the valve springs... Unless you feel like spending more money! What springs do you have (Part number)... if stock check the binding height etc and see what the spring pressures are... Once you know those you'll be able to pick a cam that is suited for those springs..
