I have a '69 343 block fitted with a 3.44 stroke 304/360 crank.
Reduced base circle cam by about .060 and heads milled about .055.
Valves are Stn Stl pieces a little longer than stock I think.
Had been assembled with CRANE silver cast Roller Rockers, Chev dimensions I guess.
To make the geometry come out right I had to use
longer push rods, 7.894, which are SBC +.100
and longer rocker studs, 1-15/16, Moroso #67820,
so the Poly locks had sufficient thread engagement.
Now I have bought the Harland Sharp 1.6 AMC Rockers.
To make the geometry come out correctly with them
I've had to go back to "standard" Studs, 1-3/4 long
and 7.700 long Pushrods, shorter than '69 stock at 7.748.
Could maybe go even shorter, but two problems arise,
The Rocker gets to close to the Stud Hex
and run out of threads on the 1-3/4 Studs with the Poly Locks.
Both sets of rockers are 1.6 ratio.
So there is definitely a difference in Rocker Geometry
when using SBC dimension rockers versus AMC (Ford) dimension rockers.
Probably no surprise to most folks here but I am,
and I have it all to owe to BullTear and this Forum.
Allow me to say THANKS to all the helpful folks here.
:t:
