In checking into the RollMaster Timing set, discovered a guy in Florida,
Nick Alfono - (847) 938-0864 & (262) 308-1302
that makes an AMC Cam Anti-Walk Kit that uses a front block face mounted plate,
and modified RollMaster Red Label Timing Set to adjust insatlled hieght.
His kit also includes the auxillary Distributor Gear External Oiling Tube.
I believe the price of his Cam Anti-Walk Kit is $259 + shipping.
So does the Torrington Bearing set-up consume Oil Volume
and scavange it from oil otherwise meant for the Distributor gears ?
I mean doesn't oil ooze out from around the Torrington Bearing O.D. ?
