I can't believe I'm hearing this information when there are known Harmful particles or shavings floating around inside the engine... 🙁:
"The small particles will be caught by the filter and I would only change oil and filter and get a new cam and lifter set".
"I second that.. also one step you might take if you can get the pan off in the truck.. pull it and clean it out (or put a magnetic drain bolt in it) but If you cant get the pan off without a bunch of aggravation.. run it.. Like MC says thats what the filter is for"..
(I don't mean no disrespect to anybody, I just disagree with what has been said).
1st: The oil filter is rated for only so much "filtering"... and with that being said the oil filter has a certain micron level that the filter will constantly filter which it is designed to catch and let the "good/decent" fluid go past... With all of these metal particles in the oil/engine the filter isn't going to work properly which will cause more fluids with the metal particles to pass by or go around.. It doesn't take much for an oil filter to clog and with an old/used oil pump... (Pressure relief valve assembly and bypass assembly) I'll be willing to bet that his engine won't see the full life that it should due to these particles running around inside... Maybe it's a good thing he didn't drop a lot of coin into this thing! But any foreign materials in the oil should always be adressed properly in-order for things to work properly for the present and the future.. This is engine is going to see premature wearing of internal parts due to these metal particles.
The Summit 8600 cam.. Is sort of pushing the limits of that stock 304.. (For getting the most performance out of it before you start losing it)..you probably would've had better results with something around a .456 gross valve lift... But then again "To one his own".. You never know though, Everybody told me that my 360 was going to be a pinger... And I'm running a little over 9:1 compression and I can run her off of Premium pump gas with no pinging... (I will say she runs strong on 103+ Octane :mrgreen: )
